'63 Steering Damper Rubber Inserts... - NCRS Discussion Boards
  • Irby G.
    • November 1, 2001
    • 267
    Anyone know where to get the rubber grommets that on either side of the steering damper? My damper still has good resistance, but rubber rot on those grommets.
    Maybe I could make some out of an old tire???
    • 43289
    Re: '63 Steering Damper Rubber Inserts...
    Irby-----
    I believe these are the same as the SERVICE lower rear shock grommets, GM #3735334. They are now GM-discontinued but are available from sources like Dr. Rebuild and Paragon.
    • Irby G.
      • November 1, 2001
      • 267
      Joe,
      Thanks for the idea. I looked at the old shocks that I took off and the rubber from those are absolutely prefect. Thanks again...Irby
