It's my understanding that the two front large motor mount bolts (WB2C)which go up from the bottom of the large motor mount cushions which then are fastened by a washer and nut have an inspection marking swiped across that nut. What color should this marking be?
C1 Front Motor Mount Bolts Inspection Marking
Re: C1 Front Motor Mount Bolts Inspection Marking
The inspection marks should be red.
Ed- Top
Can you elaborate on this marking? Is it paint? Is it a dot, or a line?- Top
I was asking about a 1962.
In addition to the top of the bolt, does the paint also go onto the nuts? Onto the washers?- Top
A number of years ago I restored a '62. The red paint was on the end of the bolt, nut, washer, as well as the radio ground strap. I doubt that there was too much concern about what was hit.- Top
Does anyone have an actual picture of an original or possibly some sort of documentation on this "inspection mark"?It's my understanding that the two front large motor mount bolts (WB2C)which go up from the bottom of the large motor mount cushions which then are fastened by a washer and nut have an inspection marking swiped across that nut. What color should this marking be?- Top
