C1 Front Motor Mount Bolts Inspection Marking - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    It's my understanding that the two front large motor mount bolts (WB2C)which go up from the bottom of the large motor mount cushions which then are fastened by a washer and nut have an inspection marking swiped across that nut. What color should this marking be?
  • Edward L.
    • 278
    Re: C1 Front Motor Mount Bolts Inspection Marking
    The inspection marks should be red.
    Ed
    • Christopher R.
      • March 31, 1975
      • 1599
      Can you elaborate on this marking? Is it paint? Is it a dot, or a line?
      • Jerry C.
        • November 1, 1995
        • 741
        What year do you have? They used to want them on 58-60 but now say it is 61-62 only. I always used fingernail polish and paint the whole top of the bolt.
        • Christopher R.
          • March 31, 1975
          • 1599
          I was asking about a 1962.
          In addition to the top of the bolt, does the paint also go onto the nuts? Onto the washers?
          • Jerry C.
            • November 1, 1995
            • 741
            Matbe on the nut but not on washer.
            • Edward L.
              • 278
              A number of years ago I restored a '62. The red paint was on the end of the bolt, nut, washer, as well as the radio ground strap. I doubt that there was too much concern about what was hit.
              • Dennis C.
                NCRS Past Judging Chairman
                • January 1, 1984
                • 2409
                WOW, youse guys have incredible knowledge way above and beyond anything I ever knowed about.
                Best regards, Dennis
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Does anyone have an actual picture of an original or possibly some sort of documentation on this "inspection mark"?
