55 owner I'm I dreaming e-bay - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 55 owner I'm I dreaming e-bay
    11:1 domed pistons in a '55? Not hardly - they were 8:1.
    • Stuart F.
      • August 31, 1996
      • 4676
      The domes are not GM either (don't look like that). Oh well, it's from Downers Grove, Illinois so you can expect anything from there. I had my carb,. fan clutch, starter and WW motor stolen by the famous Corvette shop there.
      Stu Fox
      • Cecil L.
        • May 31, 1980
        • 449
        WOW, I'll sell my 523 heads for half that, I'm not greedy.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11335
          I don't think his start bid is high enough.
          • Steven B.
            • June 30, 1982
            • 4000
            I asked the guy about the pistons and here is the reply;
            Hi,the only # on the pistons is L2148,std. which I think means left side
            hole 2,1,4,or 8. No # on rods. I had another ebay member who is a #'s
            matching guy do research on this package before I listed it. The pistons
            that go with the heads and cam that came out of the same engine are 11-1 pistons according to his books. He bought an exhaust manifold from me for a 57 that had correct # and date code. This guy knows his stuff and is building a #'s matching 57. Thats all I can tell you. I know all these
            parts came out of the same engine because it was my engine and my car and I was 20 I'm 61 now. I hope this helps. If you live close enough come and take a look. Thanks-Bill
            -jnbproducts1957
              hole 2,1,4,or 8.
              Well, that's the laugh for the day!
              • Stuart F.
                • August 31, 1996
                • 4676
                By any chance, were the piston domes facing the inside of the cylinder bores? Ah yes, I remember those 55's myself. They were the ones that came apart all by themselves. Does the rear cam bearing have a notch in it - oh, never mind.
                Stu fox
