C2 Fiberglass repair - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    The fiberglass tab that the top center of the 67 grille fastens to is broken(See photo). I want to fabricate a repair. I question whether the remaining piece of the tab has enough area to which to bond the new fiberglass. Does anyone have any suggestions?
    Thank you,
    Randy
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: C2 Fiberglass repair
    Sure, Randy, just taper the edges, apply layers of resin & matte, grind, sand, fill, sand until the repair replicates the original, drill, prime and paint.
    Be sure to elimate the cause of the original damage and that the grill does not hold your repair in a bind that may cause a re-fracture of the tab.
    Patience and Good Luck.
    HaND
    • Thomas N.
      • July 31, 2002
      • 397
      You might want to spend some time on the backside of the repair also. This is a common area that is looked at for a repair by purchasers and others.
      NCRS New England Chapter Chairman 2022, 2024
      N E Regional Chairman 2024
      1967 Corvette Convertible Under Restoration
      1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
