Original 72 mirror vs. gm replacement - NCRS Discussion Boards
  • Edward J.
    • September 15, 2008
    • 6942
    Is there a difference between an original outside mirror for 72 vs. gm replacement,(head size, shaft size etc.) other than the date,I would like to have the GM mirror dated correctly.
  • Kenneth B.
    • August 31, 1984
    • 2088
    Re: Original 72 mirror vs. gm replacement
    Paragon has the correct narrow head mirror. 65.00 for made in the USA & 12.00 to date it.
    KEN
    • Edward J.
      • 6942
      Thanks for the reply Ken, I have a gm replacement on the car thats perfect, is this not the correct size head, thanks Ed
      • Tom L.
        • October 17, 2006
        • 1439
        Be carefull, Early '72 cars have a Stainless housing while later ones are black. I read that there was a federal mandate about glare producing components had to be changed for calendar year '72. Mine was an origional stainless back, I ordered a replacemnt (black)and my restorer said it was a mistake. I checked it out and found out that there was a mid-run change.
        • Michael W.
          • April 1, 1997
          • 4290
          What do you mean by GM replacement?
          • Tom H.
            • May 31, 2003
            • 89
            Lynn, are you refering to the inside mirror? The poster asked about the outside mirror. My 72 was built in Dec. of 71 and it has a chrome outside mirror. Wouldn't this be correct for all 72's? My inside mirror has a stainless back. I hope this is what you were refering to.
            • Tom L.
              • October 17, 2006
              • 1439
              OOPS! I was referring to the inside mirror, sorry for the confusion.
              • Edward J.
                • 6942
                Mike,
                I brought a new outside mirror from the gm dealer.and was wondering for judging reasons would the mirror pass. Is it the same size as the factory. I know that the date is wrong.I can buy a dated replacement mirror from paragon reproductions .
                • Kenneth B.
                  • August 31, 1984
                  • 2088
                  Mike,
                  I beleave the GM replacement head is larger.
                  KEN
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    Edward do you still have the part number for the mirror you bought from GM?
                    • Edward J.
                      • 6942
                      Jim I brought the mirror about 3 years ago, I dont have the slip . is there a reason you need the number. thanks Ed.
                      • Michael W.
                        • April 1, 1997
                        • 4290
                        Mike,
                        Measure your mirror or post a picture and we can tell you if it's the right size head or not. Later C3s (before they went to the sport mirrors) had a wider head.
                        Buying a part at a GM dealer does not guarantee that it's right wrong or indifferent!
                        • Jim T.
                          • March 1, 1993
                          • 5351
                          Edward, I bought a few replacement mirrors about 20 years ago and still have a couple I have not used yet on my 68 and 70. Mine are still in the GM boxes with part numbers. I have a large mirror and a small mirrored one. I was going to cross check them with what you bought.
