Is there a difference between an original outside mirror for 72 vs. gm replacement,(head size, shaft size etc.) other than the date,I would like to have the GM mirror dated correctly.
Original 72 mirror vs. gm replacement
Re: Original 72 mirror vs. gm replacement
KEN65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Thanks for the reply Ken, I have a gm replacement on the car thats perfect, is this not the correct size head, thanks EdNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Be carefull, Early '72 cars have a Stainless housing while later ones are black. I read that there was a federal mandate about glare producing components had to be changed for calendar year '72. Mine was an origional stainless back, I ordered a replacemnt (black)and my restorer said it was a mistake. I checked it out and found out that there was a mid-run change.- Top
Lynn, are you refering to the inside mirror? The poster asked about the outside mirror. My 72 was built in Dec. of 71 and it has a chrome outside mirror. Wouldn't this be correct for all 72's? My inside mirror has a stainless back. I hope this is what you were refering to.- Top
Mike,
I brought a new outside mirror from the gm dealer.and was wondering for judging reasons would the mirror pass. Is it the same size as the factory. I know that the date is wrong.I can buy a dated replacement mirror from paragon reproductions .New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Jim I brought the mirror about 3 years ago, I dont have the slip . is there a reason you need the number. thanks Ed.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Buying a part at a GM dealer does not guarantee that it's right wrong or indifferent!- Top
Edward, I bought a few replacement mirrors about 20 years ago and still have a couple I have not used yet on my 68 and 70. Mine are still in the GM boxes with part numbers. I have a large mirror and a small mirrored one. I was going to cross check them with what you bought.- Top
