63 drum brake backing plate - NCRS Discussion Boards
  • Reg C.
    • 28
    Can someone tell me if the backing plates for 63-64 drum brakes are available? I am not having much luck locating replacements.
  • Joel T.
    • April 30, 2005
    • 765
    Re: 63 drum brake backing plate
    Reg;
    I have yet to see them as reproduction parts. I have seen them on eBay from time to time, but candidly, not too often. Perhaps some of the other guys will have better information for you.
    Joel
    • Harry S.
      • July 31, 2002
      • 5295
      Here is a link for full size chevy.
      I do not know if they are the same as a 63 Vette but someone, Joe, may know.
      • William V.
        • December 1, 1988
        • 399
        I do not have the part numbers available to confirm this, but I'm under the impression the brakes shoes are the same as the full size early 60 Impala. Thus the backing plates and brake cylinders and brake parts may be interchangeable. You may be able to cross referenced usable part numbers.
        • Alan D.
          • January 1, 2005
          • 2038
          Believe it's 3858826/825 for right/left and called a plate.
          The ebay items may not be correct, at least for a Mar64 car. Look for 4 holes tomount on control arm, the center area comes up to far, the hole for cylinder mount is wrong configuration and no added on support for upper center nut.
          • John A.
            • February 1, 1982
            • 48
            Try Corvette City. They're in suburbs of Chicago. Ask for lou. 847-433-6610. He might have these as he has a lot of mid year parts.
            John
            • Joe R.
              • July 31, 1976
              • 4550
              John
              John, Lou has been dead for some time. Corvette City probably does not exist anymore.
              JR
              • John A.
                • February 1, 1982
                • 48
                It's Lou jr. If he's desceased, then
                "I'm seeing dead people" I spoke with him yesterday.
                John
                • Joe R.
                  • July 31, 1976
                  • 4550
                  John
                  John,
                  Didn't know there was a Lou Jr. Excellent, I look forward to meeting him someday. Is he planning on going to NCRS Florida like his dad always did?
                  JR
                  • John A.
                    • February 1, 1982
                    • 48
                    He mentioned he was very busy right now. Since we didn' discuss FL, I really can't say.
                    John
                    • Gene M.
                      • April 1, 1985
                      • 4232
                      Is a 57 Chevy's front and or rear backing plates same as any year solid axle Corvette?
                      • William C.
                        • May 31, 1975
                        • 6037
                        OK at least per the
                        65 parts book, the '63-64 Brake backing plates 3832519 and 520 are the same for 63 and 64 pass and corvette applications, except SHP brakes. Rears are Corvette only 3847719-720 again except SHP brakes.
                        Bill Clupper #618
                        • Reg C.
                          • 28
                          Thank you all for input. I have found a used set from NCRS member.
