67 Non-DOT Whitewall - Does It Have to be 5/8"? - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    Where all the whitewall tires 5/8" for all the brands of tires that were originally installed in 67? Just wondering as it seems I can find 1" and 3/4" whitewalls in the correct tire size, but 5/8" are hard to come by. The Tech Guide only states 5/8". Are any other whitewall sizes accepted by NCRS judges for model year 1967? Thanks.
    Kirk
  • Larry M.
    • January 1, 1992
    • 2696
    Re: 67 Non-DOT Whitewall - Does It Have to be 5/8"?
    Kirk:
    The correct Goodyear 7.75 x 15 whitewall tire with 5/8 inch whitewall width is available from Kelsey Tire. Listed in the "Performance 2" section of their webpage.
    Search Our Tire CollectionSearch for Tires by Size, Sidewall Design, or Year of the VehicleGoodyear Collector SeriesKelsey Tire is the exclusive distributor
    Larry
    • Kirk M.
      • June 30, 2006
      • 1036
      Thanks. Got four of those coming, but I was looking for an original Non-DOT tire to put in the spare.
      • Larry M.
        • January 1, 1992
        • 2696
        Kirk:
        Old RESTORER articles indicate 5/8 inch whitewall is the correct size. If you have an otherwise correct, non-DOT tire with a 3/4 inch whitewall, you might get past some of the judges some of the time.
        However, a 1 inch wide whitewall .....no way.
        Larry
        • John S.
          • February 1, 2003
          • 78
          Kirk.. are u coming to OLD TOWN next week..if u are my adrs is j57vette@aol.com
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1463
            Kirk,
            current judging standards allow full credit for a spare of Typical Factory Production, which in this case does not have to match the four on the ground.
            So, if you are lucky enough to find an original "Redline" or "Black wall" worth the money, you might consider snapping it up for full credit until you locate your 5/8" WW.
            HaND
            • Randy R.
              • March 1, 1983
              • 477
              If anyone knows of a readily available radial tire with a 5/8 in white wall, please share the brand and model no with us. I have been unsuccessful in my search for such a tire to use for driving purposes.
              Thank you,
              Randy
              • Kirk M.
                • June 30, 2006
                • 1036
                Thank you,
                Randy
                Randy,
                Diamondback makes a 5/8" ww radial. I almost bought those instead of the bia plys.
                • Kirk M.
                  • June 30, 2006
                  • 1036
                  No I am not. What exactly is it?
                  Kirk
                    Originally posted by Kirk McHugh (46057)
                    Randy,
                    Diamond Back will make you radial whitewalls with any width whitewall you want, positioned any distance from the rim that you want.
