undercoat removal help.. - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5202
    Trying to remove undercoat on this tire lid but I think my heat gun is too small, is there a better method, PIA!!!! Comments and suggestions are appreciated. How about paint stripper??
  • Alan D.
    • January 1, 2005
    • 2054
    Re: undercoat removal help..
    Hit with home heating oil, let set, blow off with pressure washer. Get rest off with brake cleaner spray (good ventilation a must). I'm assuming undercoating is the old stuff.
    • Chuck G.
      • May 31, 1982
      • 2039
      Kerosene and some plastic scrapers, either the type you use for drywall or the type you use for spreading Bondo.
      Chuck
      • Timothy B.
        • April 30, 1983
        • 5202
        Thanks Alan and Chuck, Kerosene it is because it's supposed to be odorless, I will try tomorrow in the garage.
        • Tom L.
          • October 17, 2006
          • 1439
          I used Gunk engine degreaser on mine and it worked fine. Just have to be patient and wait for it to do its thing before trying to remove the coating.
