Help to ID 61 Saginaw - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 821
    Please help. This should be my original transmission in my 61. Build date of the car was 12/12/60
    Below the number 8748888 is
    *J 81 0
    Thanks guys.
  • Ridge K.
    • May 31, 2006
    • 1018
    Re: Help to ID 61 Saginaw
    *J 81 0
    Thanks guys.
    Bob, wouldn't the original standard transmission in a 1961 Corvette be a Borg Warner?
    • Bob H.
      • July 31, 2000
      • 821
      It's a 3 speed. I think the 4 speed was Borg Warner
      • Ridge K.
        • May 31, 2006
        • 1018
        Gotcha, Bob. My mind was on four speeds this morning.
        Hopefully, by getting your post back up to the top, some help will come forward today.
        Good luck, and a Happy New Year! Ridge.
        • Cecil L.
          • May 31, 1980
          • 449
          Bob,
          The main case casting number should be 3743368.The number you posted could easily be misread if it's a rough casting or caked with dirt. Also I would expect the date code you posted would be good if it read J 18 0 instead of J 81 0.....could you have transposed the 1 and the 8?
          For further verification, your side cover should be 3731911 which is exclusive to Corvette as well as the 3787067 tailshaft housing (extension housing).
