Can anyone recommend a place to get the 53-55 starter relay restored? I want to make sure this one works right before moving forward. Appearance is a secondary issue.
Source for starter relay resto
Re: Source for starter relay resto
Have you checked to see if it works yet ,it's simple inside ,it's like a light switch ON or OFF
Connect a hot wire to the left side post then ground the other side post and you will hear a CLICK .Then you know it works. Use Borax to clean the mount and posts , paint the cover and it's restored
Or send it to some one and spend big $$$ to get the same thing
