Source for starter relay resto - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    Can anyone recommend a place to get the 53-55 starter relay restored? I want to make sure this one works right before moving forward. Appearance is a secondary issue.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Source for starter relay resto
    Have you checked to see if it works yet ,it's simple inside ,it's like a light switch ON or OFF
    • Troy P.
      • February 1, 1989
      • 1284
      It may work. Not sure how to test it though. Still I'd like to get the appearance up to snuff too.
      • Roy B.
        • February 1, 1975
        • 7044
        Connect a hot wire to the left side post then ground the other side post and you will hear a CLICK .Then you know it works. Use Borax to clean the mount and posts , paint the cover and it's restored
        Or send it to some one and spend big $$$ to get the same thing
        • Roy B.
          • February 1, 1975
          • 7044
