C3 rear end code - NCRS Discussion Boards
C3 rear end code
  • Doug F.
    • November 10, 2006
    • 26
    C3 rear end code
    Could someone please de-code this: 2 CAM 7 2 70 W. I know it's a 3:36 built at the Warren plant. Would this rear be correct for an early Jan '71? Thanks as always.
    • 43263
    Re: C3 rear end code
    Doug----
    No, it wouldn't. For one thing, unless the car was built on January 2, 1971, the unit would fall out of the NCRS/NCCB "6 month rule" (which, incidentally, is very generous as it is).
    More important, though, is the fact that the "CAM" axle code is a 1970 code. A different, 2 alpha character coding system was used for 1971. Is it possible that a very early 1971 might have used a 1970 coded rear end? Yes, it's possible, but a January, 1971-built car is not a very early 1971.
    • Doug F.
      • November 10, 2006
      • 26
      What is the difference between the "LR" and "AX" codes, (both 3:36) for a '71 rear?
        • 43263
        Doug-----
        I expect the difference is the type of stub axles installed. One would use the standard u-bolt style axles and the other would use the heavy duty, cast iron cap type axles. The standard u-bolt type axles would be used on base engine cars and the HD on all big blocks and LT-1. However, I don't know which code represents which axle type.
