Painting the LT-1 Hood Stripe
Re: Painting the LT-1 Hood Stripe
When I have an original hood stripe LT1 at a Regional or National I spend 15 minutes or so explaining how to spot original stripes and why the edge has the kind of edge it does. The "feathering" that Ken speaks about is from the original mask which was made differently than the one you bought. The original mask, made by a steel rule die, is no longer available and probably never was available outside St. Louis. The masks today are cut part way through with a laser; a technology that wasn't used in 1970-72.
There is a description of this, and a drawing showing the tufts the steel rule die left in the mask in the 1970-72 TIM&JG. Check it out.Terry- Top
1. Template piece misalignment. Judging Guide
2. The edges cannot be straight (small indentations). Judging Guide
3. The edges need to have feathered look. Member advice- Top
Hi Bryan,
That's an interesting question.
I would start by doing some test stripe sections. I would apply the tape, (not from your kit), and then gently rub the edge of the tape with a clean, but crinkled -up, piece of paper towel, hopefully there is a tiny bit of adhesive residue on the tape edge that will grab some of the lint from the paper towel and give you a less than perfect paint edge. I'd then try it for real on your hood.
I know, that's really 'wish-n and hope-n', but that's what I would try.
Alan71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
- Top
Hi Bryan,
Sounds like it might work. The kit does come with a small extra piece of stripe stencil that can be used for test purposes.- Top
I think they are all outward -- peaks. The tell-tale is that they are all in line on each of the stripe edges. One can't always see all of them, and some stripes don't have any. I suppose it depended on how the line worker pulled the stripe out of the mask. What you are looking for are the little tufts left behind when the stripe was lifted from the main part of the mask. The mask was slit for an inch or so, and then there was a small < 1/16-inch solid space before the next slit began. This allowed the worker to lift the mask in the area that was to be painted, and the stripe "popped" out of the mask as each solid portion was torn.
You need to see the drawing in the TIM&JG. It is easier to describe if you have either the real deal in front of you, or the drawing at hand. I suggest you delay proceeding until you have the opportunity to examine one or more original hood stripes. There are lots of ways to F it up, and only one way to get it right. And after looking at one you just might decide it is not worth the risk and effort to try to duplicate the original. I have yet to see anyone succeed, but there is always a first time.Terry- Top
I do have the JG diagram for reference. I might just have to settle for the getting the hood closer to the correct color and template piece misalignment.- Top
KEN 260 927 6891Last edited by Kenneth B.; December 12, 2008, 03:29 PM.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
