1962 Jack and tools - NCRS Discussion Boards
1962 Jack and tools
  • John F.
    • March 23, 2008
    • 2419
    1962 Jack and tools
    Let me try again. Can someone post pictures of a 62 jack and tools with top and bottom plate and any stampings? Thanks!
  • Bill O.
    • April 1, 2006
    • 542
    Re: 1962 Jack and tools
    John,
    Here are pictures of an unrestored original '62 jack. I'll take some pictures of the tools later today.
    Hope this helps.
    Bill
    • Mike E.
      • February 28, 1975
      • 5141
      If you have the Corvette Restorer CD, there is a past entire article with pictures of the 53-61 and 62 jacks, with descriptions of both. It wouldn't be a bad idea to check out what's already been done.
      • Bill O.
        • April 1, 2006
        • 542
        John,
        Tools.
        Bill
        • John F.
          • March 23, 2008
          • 2419
          Bill, thanks so much! John
          • John F.
            • March 23, 2008
            • 2419
            Bill or anyone else with a 62. Can you give me the dimensions of the jacking tools such as the lug wrench and the jacking handle (as it is in the trunk holddown area and opened out of the car). John
            • Gary C.
              Administrator
              • October 1, 1982
              • 17940
              John, attached are drawings for the jack tool and tire wrench. Believe these drawings were in effective through '62. Gary....
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • John F.
                • March 23, 2008
                • 2419
                Thanks Gary! Very helpful....John
                • Bill O.
                  • April 1, 2006
                  • 542
                  Gary and John -
                  Dimensions may be spot on but the tang at the end of the jack handle was not spoon shaped for '62 as in the drawings but instead as shaped in my earlier posting. Same is true for the lug wrench where the drawing shows the hub cap removal end almost straight with the handle. In '62 it had a very pronounced bend at this point. Also see earlier jpg.
                  John, look for the raised letter "O" (Otterburn Manufacturing Co.) on the lug end of an original lug wrench. CC 's repro at least when last looked does not have the "O".
                  These drawings, at least from appearance, seem to be for '61 and prior.
                  Just to clarify.
                  Bill
