Tar on upper evaporator tube for '67 - NCRS Discussion Boards
  • Robert C.
    • December 1, 2005
    • 164
    Any idea who sells the thick "tar" like substance on the upper evap tube?
    It's the insulation that covers the expansion tube.......
    I just started looking around and haven't seen anything. Searches on NCRS didn't turn up anything.......at least what I was searching with so far.
    Thanks for any help, Bob
  • Robert C.
    • December 1, 2005
    • 164
    Re: Tar on upper evaporator tube for '67
    I might of found it.
    Old Air Products "tacky tape insulation" looks like it.
    Bob
      Also available in good auto parts stores in a blister-pack under the "Motormite" brand, #34312 "Cool-Aid" Insulation Tape, 2" x 12".
      • Robert C.
        • December 1, 2005
        • 164
        Thanks John, I'll nose around and see if anyone around here sells it.....
        • Lorne G.
          • June 30, 1988
          • 118
          I purchased this wrap at Dr. Rebuild. They also have the gaskets, seals etc. for the A/C units.
          I believe they advertise in the Driveline.
          Lorne
          • Robert C.
            • December 1, 2005
            • 164
            Thanks for the tips ! Forgot about them.
            As John noted Motormite sells this tape. Motormite is owned by Dorman. Our local NAPA dealer couldn't special order the tape, but I'll check with
            Autozone, since they sell alot of Dorman products.
            I'm looking for Dr. Rebuild as I type this ! Appreciate the tip.
            Bob
            • William B.
              • April 30, 1975
              • 942
              Go to any heating and air conditioning supply house. I found it in big 12" x 12" pieces. Was able to better make it look like factory than the auto parts houses that sell it in long thin strips.
              • Mike M.
                • May 31, 1974
                • 8400
                the real mccoy is available fromAC Delco, part #12301731. comes in a roll, about 25" long and the correct width(about 2").i've got a full roll. let me know how long a piece ya need, your sanil mail address, and i send ya a piece(on the cuff)mike
                • Robert C.
                  • December 1, 2005
                  • 164
                  Mike,
                  I tried the AC Delco number, but nothing comes up......called my GM dealer too.
                  Any idea how old the p/n is? Or what GM uses or calls the stuff?
                  My parts guys aren't big on searching.
                  I have a HVAC place down the road, so I guess I can look there too. Never thought it was used in the HVAC world, but probably used just the way we use it on Corvettes.....
                  Bob
                  • Ken A.
                    • July 31, 1986
                    • 929
                    Try any of the big box hardware stores, they stock the correct stuff & it's cheap!
                    • Page C.
                      • February 1, 1979
                      • 802
                      A couple of other sources: Napa #20-9535. Also NRP(national refrigeration products) #NRP-1. Both call it "cork insulation tape".
                      Regards
                      Page Campbell
                      • Robert C.
                        • December 1, 2005
                        • 164
                        NAPA did locate it, Part Number TEM 209491. Roll is $20 bucks.
                        Thanks for all the replies.
                        Bob
