'60 door panel repair - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    On a '60, what is the best fix where the doorpanel screws go into the fiberglass under the panel? Since there are no nuts used, the screws just pull out of the fiberglass.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '60 door panel repair
    I've used thin sheet metal glued on the back side , never will strip again
    • Mike M.
      • May 31, 1974
      • 8408
      agree with roy. use metal on back side but i rivet the metal in place. its time consuming to do all the screw holes on both doors but worth it.mike
      • Steven B.
        • June 30, 1982
        • 4014
        I have used plastic anchors---my advise don't. They do not hold. The sheet metal works very well. Vendors have a "repair kit" but I have never used one.
        • Joe M.
          • February 1, 2005
          • 590
          Re: '60 door panel repair- use j-nuts
          • Mike M.
            • May 31, 1974
            • 8408
            Originally posted by Joe Mish (43421)
            good idea and much quicker than mine.mike
