65 heater housing - NCRS Discussion Boards
65 heater housing
  • Donald S.
    • January 23, 2008
    • 183
    65 heater housing
    was the engine side /the outer heater housing painted or raw fiberglass???thanks Don
  • Donald T.
    • September 30, 2002
    • 1319
    Re: 65 heater housing
    Don,
    It should be unpainted natural fiberglass.
    • Donald S.
      • January 23, 2008
      • 183
      thought so but now the trick is to remove the paint without damaging the fiberglass.. thanks Don..
      • Tony S.
        NCRS Vice President, Director Region VII & 10
        • April 30, 1981
        • 993
        Probably will have a narrow strip of black out paint just along the top of the fiberglass assembly. Not much, but I don't believe that it was masked off during black out.
        Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
        Original member of the Kansas City Chapter, est'd 07/11/1982.
        Member: 1965 and 1966 National Judging Teams
        Judging Chairman--Kansas City Chapter.
        Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
        • Donald T.
          • 1319
          The heater box would have been installed after blackout, so no paint should be present. I think you are referring to the sealer that may have been present along the edge.
          • Mike M.
            • May 31, 1974
            • 8408
            don is correct. no black out paint but rather a tar-like substance sloppily dripping down over the housing and also on the firewall to a limited extent.rest of housing bare fiberglass. lacquer thinner will remove the mess without haqrming the fiberglass housing. mike
            • Donald S.
              • January 23, 2008
              • 183
              did all have that slopy tar like sealer or was it only applied after the water leak test as they tried to fix a leak thanks again guys Don..
              • Rick S.
                • January 1, 2003
                • 1203
                Here is a picture of my 67 , showing the goop.
                Rick
                • Dale S.
                  • November 12, 2007
                  • 1224
                  My 67 has a small amount of black goop. It looks as if it was put on the firewall, then the heater box bolted on and the excess pushed out slightly. I have one spot where the excess was enough to run over the edge of the heater box. It ran about a 1/2 inch down the box. It has A/C and most everything is hidden. Not near the amount on the picture posted. Dale
                  • Rick S.
                    • January 1, 2003
                    • 1203
                    Here is another photo when engine was out for rebuild.
                    Rick
                      Some cars have none, some have a lot; it was used at water test for leak repairs.
