C1 Steering Wheel Mount - NCRS Discussion Boards
  • Richard H.
    • March 1, 1985
    • 241
    Mounting steering wheel for the first time and when the nut seems to be fully tightened, there is approx a 5/8" gap between the hubs. The spring that lies on the shaft seems to keep it from moving closer together. Does the spring need to be installed in a different manner? What is the solution? Thanks. Richard
  • Richard H.
    • March 1, 1985
    • 241
    Re: C1 Steering Wheel Mount
    Another thought, the inner hub is mounted flush to the instrument pod, sliding over a small tab at the top of the shaft. Could this be moved up, closer to the steering wheel hub, to overcome the gap issue?
    • Mike M.
      • May 31, 1974
      • 8408
      loosen the pan head phillips machine screw that clamps the directional signal housing to the steering col mast jacket and slide the dir signal housing to within a 1/4 to 1/8" of the steering wheel hub. mike
