66 Brake line clip - NCRS Discussion Boards
66 Brake line clip
  • John M.
    • January 1, 1998
    • 813
    66 Brake line clip
    Can someone help me with some approximate dimensions for the location of the green brakeline clip on the front frame crossmember? In the AIM it looks like it's off-center but there are no dimensions. This is a new frame with none of the gasline, brakeline holes drilled. I'v been copying a 67 but the line is different on the 66 in this area.
    John McRae 30025
  • Robert B.
    • May 31, 2005
    • 163
    Re: 66 Brake line clip
    This picture may help - this is my original 66 coupe's front brake line mount -
    Bob
    • John M.
      • January 1, 1998
      • 813
      Thanks Bob,
      That looks like dead center near the top. The repro clip that we have doesn't look like that one but I think I'll use it anyway. It's like the two used on the crossver in the rear where there's one on ech side.
      John
      • David C.
        • May 17, 2007
        • 62
        I believe early 66's did not have the clip and one of the members was doing research as to approximate when the changeover occured
        • Larry S.
          • September 19, 2007
          • 204
          I have an early 66 (BB serial #1508) and when I get home on Monday I will check for a clip on the front cross member and get back to you.
          • Gary B.
            • February 1, 1997
            • 7069
            66 Brake line clip; changed during the model year
            I believe that early '66s had the spring-like clip at the center and later cars used the two screw-based clamps about 18" on either side of the center, but no longer used the center clip. Check the archives as someone was definitely researching when the change-over occurred.
            Gary
            • Larry S.
              • 204
              My early "66 big block (ser#1508) has the clip in the center like the pic that you received earlier. It is as it was prior to frame off rebuild.
