Correct 63 expansion tank cap - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    I'm trying to sort out what cap markings are correct for my early 63 fuelie(September -October 1962 build). Apparently there are 3 versions of the 307 cap.
    1. AC logo 13# and 307 all on one ear and not circled
    2. AC logo on one side circled and 13# 307 on the other not circled
    3. AC logo on one side circled and 13# 307 circled on the other
    Is this correct and which one do I need?
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Correct 63 expansion tank cap
    I would think you would need the first one.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Troy P.
      • February 1, 1989
      • 1284
      The judging manual says it does not have a circle around the 307 13# designation but does not mention if there is or is not a circle around the AC. This is the cause of my confusion.
      • Stan E.
        • April 30, 1991
        • 383
        Original caps had a brass rivet in the center.
        • Jeffrey A.
          • October 22, 2006
          • 273
          If you have Nolan Adam Restoration Book on Page 86 show you a good picture of what you are looking for I believe.
          Jeff Aiello
          NCRS 46414
          • Peter L.
            • May 31, 1983
            • 1930
            Stan - The original AC 307 radiator pressure caps used an aluminum center piece so the exposed end at the center of the cover that looks like a rivet is aluminum. Pete
            • Paul G.
              • August 31, 2006
              • 66
              I think this is the cap in question:
              • Troy P.
                • February 1, 1989
                • 1284
                Good photo. This is the 61 to early 63 cap - the #1 described in my post. I question if the #2 actually exists. It may be an ambiguity in the judging manual. However, Dewitt's on-line catalog indicates they can provide such a cap.
                • John D.
                  • December 1, 1979
                  • 5507
                  Peter, When I read Stans post on the brass I said outloud "really". I talk to myself a lot.
                  Thanks for clearing that up. I have seen some that have been restored though that have the brass rivet and thought they were incorrect. Just yesterday I looked at one and it has the aluminum rivet. The same car also came with a round glove box door key.
                  • Troy P.
                    • February 1, 1989
                    • 1284
                    I agree. It's not really a rivet, it's part of the inner pieces and is folded/peened over to hold everything together. None of the innards are brass.
                    • Timothy B.
                      • April 30, 1983
                      • 5193
                      Is there supposed to be a gasket just under the top? I ask this because I used a AC doner cap for the sealing gasket and also took the larger gasket and installed it like is was on the doner cap.
                      • Peter L.
                        • May 31, 1983
                        • 1930
                        Tim - Yes, the original AC #307 and RC-26 radiator pressure caps with the aluminum "rivet" used a large "fiber" gasket under the large aluminum washer that is directly under the cover. Pete
                        • Peter L.
                          • May 31, 1983
                          • 1930
                          John - We've both seen stranger things but brass "rivets" on original AC #307 and RC-26 radiator pressure caps is not something I have come across yet.
                          With regards to the round head GM/Briggs & Stratton key with the "correct" KEY NUMBER on the KNOCK OUT for the glovebox lock, I believe it is unique to a very special ermine white 1963 coupe with FI; but this is only a theory.
                          Pete
                          • Troy P.
                            • February 1, 1989
                            • 1284
                            Wonder why they don't put the large fiber "washer" in the repo caps? Seems like it would be easy to do during assembly.
                            • Paul G.
                              • August 31, 2006
                              • 66
                              This is the cap off my 65 365hp coupe. I thought this cap is correct for a 65 shp small block without air.
