belt length 70-72 - NCRS Discussion Boards
belt length 70-72
  • Lyndon S.
    • April 30, 1988
    • 1027
    belt length 70-72
    What is the right length belt for the LS-5 water pump crank? With AC/PS,
    _______
    Kelly
    • 43218
    Re: belt length 70-72
    _______
    Kelly
    Lyndon-----
    15/32" X 31-7/8"
    • Lyndon S.
      • April 30, 1988
      • 1027
      Anyone have a part number for that belt in gates?
      ______
      Kelly
      • Dick W.
        • 10483
        Your Gates jobber should be able to to come up with that number, but it should be a 7325
        Dick Whittington
        • Lyndon S.
          • April 30, 1988
          • 1027
            • 43218
            Kelly-----
            The Gates 7312 is 31" in length. I don't think that will work for this application. Basically, except for reproduction, there is no exact match for the original GM belt.
            For non C-60 applications with N-40, the exact length belt is necessary. However, for with C-60 applications , the idler pulley provides a slight amount of adjustment. I still don't think that a 31" belt will work, though. A 32" or 33" belt might work, though.
            • Lyndon S.
              • April 30, 1988
              • 1027
                • 43218
                Kelly-----
                That's the original length. However, I expect that the Paragon belt is a reproduction and not a standard, current-manufacture belt.
                • Lyndon S.
                  • April 30, 1988
                  • 1027
                  • Lyndon S.
                    • April 30, 1988
                    • 1027
                    Joe
                    Are any belts available for the LS-5 cars with AC/PS ect from GM anymore?
                    _____
                    Kelly
                      • 43218
                      Joe
                      _____
                      Kelly
                      Kelly-----
                      All original belts for pre-73 Corvettes were wrapped style belts. There are NONE of that type available from GM and there have not been for a LOT of years. As far as replacement style, CUT belts, there are a few still available. The fan/generator belt for LS-5 with C-60, GM #9433761, is still available and the power steering belt for LS-5 with C-60 and N-40, GM #9433725, is still available. That's it.
                      • Lyndon S.
                        • April 30, 1988
                        • 1027
