Chevrolet 3 speed. - NCRS Discussion Boards
Chevrolet 3 speed.
  • Dale S.
    • November 12, 2007
    • 1224
    Chevrolet 3 speed.
    I have a Chevrolet 3 speed transmission. I dont know what it is for. I think I bought it for a spare for my 62 Chevrolet truck. The casting number on the tail housing is 3855710 and an E 106. The case is 3834197 and 12 83 . The side cover is 3849534. I dont know if it goes together or a bunch of parts. It appears to have not been apart. Thank you in advance. Dalel
    Re: Chevrolet 3 speed.
    Colvin shows the 4197 main case as used on '64 Corvette (that date code is probably I 28 3), the 5710 tailhousing as used on '65 Corvette, and the 9534 side cover as used on '64-'65 Corvette. Have no clue about truck applications.
    • Dale S.
      • November 12, 2007
      • 1224
      John, Could this be a 64 or 65 Corvette 3 speed? I will get the rest of the date codes. Anything else I should look for? Thank you Dale
      • Dale S.
        • November 12, 2007
        • 1224
        Does anyone know how many 3 speeds were built in 1964 or 1965. I have Rowleys figures for 1967. M-20+ M-21+ M-22 less total of 1967's built= 201 3 speeds. Is this correct for 1967? Thank you Dale
          • 15676
          If it was installed on a vehicle at a plant, it should have a stamped VIN derivative.
          Also, the Corvette ratio set is 2:47, 1.53, 1.00:1, and this ratio set may have been unique to Corvette.
          Subtract the number of all transmission options including M-35 from total vehicle production to determine the number of base three-speeds.
          • Dale S.
            • November 12, 2007
            • 1224
            Thank you Duke, I will check for Vin number. If it goes to someones car I would like them to have it as it went to my car I would want it. I will post what I find. Thanks again Dale
