C1 '58 Hood Hinge - Bubba at work? - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    In looking at my original '58 hood hinges it looks like Bubba has been at work on the front bolt slots. This sure doesn't look like GM does it?
    They're at least fairly symetrical.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 '58 Hood Hinge - Bubba at work?
    You should see what they do to 53-57's trying to adjust the body line or poping up action.
    • Edward M.
      • November 1, 1985
      • 1922
      Could be original. THe hinges on my 56 have a lot of that "slotting".
      • Mike M.
        • May 31, 1974
        • 8408
        work of bubba fer sure.mike
        • Steven B.
          • June 30, 1982
          • 4011
          'Looks like someone got a little carried away! that is not like any I have seen B4.
          • Roy B.
            • February 1, 1975
            • 7044
            The only reason for seeing the slotting on 53-57 is because people don't understand the pop-ups or how to adjust the hinges for the hood to meet the front body line.Every time you see some one placing their hand under the front of the hood to aid it to open they don't understand how to adjust things.
            • David K.
              • February 1, 1976
              • 592
              Another cause for this kind of "adjustment" is the correct shimming of the core support. As you know this supports the whole front body. So if the shims are not accurately placed the front end sits low and then the hood doesn't fit right until this is done.
