L 88's - NCRS Discussion Boards
L 88's
  • Wayne M.
    • March 1, 1980
    • 6414
    #31
    Re: L 88's
    Originally posted by Tom Marcucci (22001)
    ..... IT looks like a "H" after IT , What is that ??? Tom
    Tom -- on P-o-P's, means Holley Carb.
    • Tom M.
      • 716
      #32
      Re: L 88's
      Is that 67 only ? I don't remember seeing that in 68 /69 ??
        • 11668
        #33
        Re: L 88's
        I know 70-72 LT-1s with the H occasionally seen on the blue Certification sticker on the door, so I'd guess that 68-9s have the H too.
        Patrick
        • Tom M.
          • 716
          #34
          Re: L 88's
          Patrick
          Not on all L88,LT-1,LS6, CARS ??
            • 15616
            #35
            Re: L 88's
            H = Holley
            R = Rochester
            Comes up on PoP in 68 and up once in a while. Nothing consistent. It shows up on the blue door label because in 1969 to 1971 that blue label information is imprinted from the PoP, and if the label is misaligned when the imprint is taken the next line below the VIN shows up on the blue label.
              • 11668
              #36
              Re: L 88's
              Probably, but I was just giving my observations.
              You can make your own extrapolations regarding other motors.
              • Tom M.
                • 716
                #37
                Re: L 88's
                thanks Wayne, but it's not on all POP , 20% ???
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  #38
                  Re: L 88's
                  Tom -- I can only say what is in the '65 AIM, 'cause that's all I have. Instructions for what data is to be stamped on the P-o-P and the starting location of the fields is given. Ref UPC 14, Sheet C10. [presented as a grid of columns & rows].
                  In the example below, "engine source, date & type code & number" was to begin at G1 (line G, left hand margin). The "Carburetor source" was to be located at G10. Counting from left, we see that, indeed, the H is the 10th column from the left margin. Don't know if '67 AIM says carb is to be at G8 (because in L88 example I gave above, it follows directly after engine code).
                  • John C.
                    • January 1, 2005
                    • 616
                    #39
                    Re: L 88's
                    The 67, 68, and 69 AIM all show that the carburetor source is to be stamped at the end of line 1 (position A29).
                    My 68 has it there but also directly after the engine code as shown in the picture.
                    John
                    • Tom M.
                      • 716
                      #40
                      Re: L 88's
                      Wayne, Yes the "H " has a space between the engine code the same as yours, The POP from The 67 L88 Tony Delorenzo car had it right next to it, no space.
                      REGARDS TOM
                      • Tom M.
                        • 716
                        #41
                        Re: L 88's
                        What about this L88 AT Barrett Jackson lot # 1247
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          #42
                          Re: L 88's
                          http://www.barrett-jackson.com/appli...LotNumber=1247
                          Ah yes ! ..... back when it made its first public "debut", it even had "confirming" paperwork from 1968 showing service parts that were L-88 [you can make out 3rd gear M22-only #3880845]. Notice the P-o-P imprint; not much resolution in this pic, but I can read VIN 02390. You can see the 'H' immediately after the 'IT' engine code .
                          Other P-o-P #'s: T1011IT; FC0919W; P7M29(?).
                          Is the auction held yet ? if so, what $$$ did it pull ?
                            • September 30, 1999
                            • 710
                            #43
                            Re: L 88's Check out this site
                            This website is an online photo gallery of the cars in Kevin Suydam's extensive Musclecar collection. This collection consists of over 100 plus of the rarest Corvettes and American high performance muscle cars ever produced. Click on each category thumbnail to enter that particular group. To view full sized photos, doubleclick on thumbnail photos to enlarge them. The website is constantly in process of updates. Keep checking back as there are over 10 cars in various stages of restoration yet to be posted. There are also newly obtained cars for which good photos need to be taken, weather permitting. *Update* 1/11/23 Added approximately 25 cars (Mostly Mopars) but need to add more photos of each car, such as interior and engine compartment. Then type descriptions for each one. Kevin is always interested in adding to his collection--specifically American and Canadian high performance muscle cars and Corvettes. His primary interest is the 1967 to 1971 model years and the cars could be restored or in need of restoration but they must be authentic. If you yourself have such a supercar, factory or dealer high performance car or race car for sale, or know of others email Kevin.
                            • Steve B.
                              • March 1, 2002
                              • 1191
                              #44
                              Re: L 88's
                              Not real, nuff said
                              • Peter G.
                                • September 30, 1992
                                • 135
                                #45
                                Re: L 88's
                                Originally posted by Steve Bramati (37512)
                                I believe the TD 67 L88 is in the book but was not black at the time that it was photograhed. I believe this books emphasis is on the L88 Corvettes that were raced. The author is considering doing another book that focuses on the "street L88s"
                                Thanks for all the nice words guys! I have a few color photos of Tony DeLorenzo's black '67 L-88 when it was black. Without opening it up, I think I have three color photos of his car from 1967 and 1968. Plus I have a lot more of all the other "racing" L-88s.
                                Nice to be here in the discussion boards!
                                Pete
                                www.TheL88Corvette.com
                                www.corvetteracinglegends.com
                                Dr. Pete
                                www.CorvetteLegends.com
