Hi all, Just trying to figure out the correct place for the vacuum lines onto the rochester carb. At the moment the line on the front left lower side is going to the distributor & the one one the right at the top is going to a canister behind the side grills on the L/H side. The Dobbins book shows the lines set up opposite. Which is correct & does it make a difference?
Thanks in advance, Steve
