'56-'57 wheel covers - NCRS Discussion Boards
  • Michael P.
    • June 30, 1977
    • 31
    Is there any way to determine a set of reproduction wheel covers from the original ones, other than the obvious dings from 50+ years of use?
  • Joseph T.
    • April 30, 1976
    • 2074
    Re: '56-'57 wheel covers
    I am not sure if the repos have the manufactuer stamp near the air valve hole on the reverse side.
    Others will reply.
    • Roy B.
      • February 1, 1975
      • 7044
      Repro's dont have the factory markings you see here , this is how you know your looking at original's.
      • Michael P.
        • June 30, 1977
        • 31
        That's easy enough! Thanks Roy.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          This is great info, however, it might be worth mentioning that if you are having your car judged, the judges will not be able to see this stamping.
          • Steven B.
            • June 30, 1982
            • 3990
            I was advised finish of the center of the spinner, with the wording and crossed flags, is different than the originals. Is this accurate?
            Steve
            • Ted S.
              • January 1, 1998
              • 747
              The originals have a ice blue tint verses repos are a little yellowish in the sunlight also.
