69 Cowl panel access panel? - NCRS Discussion Boards
+ More Options
Posts
  • Greg L.
    • March 1, 2006
    • 2291
    Does anyone know what this panel is for?
    It's right behind the brake booster if it helps.
  • Bill C.
    • July 15, 2007
    • 904
    Re: 69 Cowl panel access panel?
    it is not an access panel.
    the plate is a support plate. The 4 bolts that go through it secure the brake/clutch/column support components uder the dash area inside the car.
    • Greg L.
      • March 1, 2006
      • 2291
      oh...
      And here I thought it was some "secret" panel that would let me get at those top booster nuts...
      Thanks Bill.
      • Bill C.
        • July 15, 2007
        • 904
        I kind of thought the same thing -- I removed it and nothing behind it.
        I could not figure what it was for - not until I did the body-off resto, then I figured it out when I tried to get the pedal assembly out.
        trust me - I was equally as bummed out. I had to do work under there when I first got the car. removing that booster SUCKS!
        I have NO idea what they were thinking about when putting those nuts up there, specially the one up top and to the left side YUK.
