source for convertible clamp rubber - NCRS Discussion Boards
+ More Options
Posts
  • Greg H.
    • June 2, 2008
    • 254
    Hi all,
    For the clamp to hold the front of the convertible top to the windshield, I see I can buy replacement adjustment screws with rubber bumpers. Has anyone found a source or idea to replace just the rubber part? I hate to replace a good original adjustment screw just for the rubber.
    Greg
    • 43263
    Re: source for convertible clamp rubber
    Originally posted by Greg Heitman (49079)
    Hi all,
    Greg
    Greg-----
    You can use diaphragm material (rubber with nylon cord) or another high durometer rubber material. However, you'll need to obtain these from an industrial supplier like McMaster-Carr or Grainger. Then, you cut out the small discs using a cork-borer or arch punch. Last, glue it on using 3M Super Weatherstrip Cement. However, after you do all this, I think you'll find that it's going to be WAY cheaper just to buy the reproduction screws. I once rebuilt these screws using this method and it worked PERFECT. However, I had access to scraps of the material where I used to work and also had available there a cork-borer and a set of arch punches. So, my cost was minimal.
    You can also use any old rubber material you can purchase in a hardware store but it probably won't last too long because it will be too soft.
