Cubic Inch Calculation Table - NCRS Discussion Boards
  • Steven B.
    • June 30, 1982
    • 4011
    Does a table exist anywhere that shows the Bore and Stroke and resultant Cubic Inches for production and non-production small block displacements? I am interested in the Bore and Stroke combinations for 331, 339 and other displacements. I could always get out my calculator but if it exists------
    Thanks!
    Steve
  • David T.
    • August 31, 1995
    • 51
    Re: Cubic Inch Calculation Table
    Try this link.
    This script determines the displacement of the engine by two methods; selecting the engine to get the geometry of the configuration, or by the geometry to get the engine.
    A Google search for engine displacement calculator turned up several others.
    Dave T.
      • 15706
      That's an excellent site for online calculators.
      The list of their automotive calulators/converters is here:
      and I commonly use their compression ratio calculator:
      This calculator is designed to show the different Compression Ratios for different sized engines.
      • Steven B.
        • June 30, 1982
        • 4011
        Thanks! These are very helpful and save a bunch of time instead of using calculator or slip stick (yes, I still have a couple).
        Anyone know bore and stroke for a 337 CI and 331 CI? Both based on 283 block.
        Thanks!
        Steve
        • Michael H.
          • January 29, 2008
          • 7477
          Thanks!
          Steve
          Steve,
          Trying to wring 331 inches out of an old 283 block may be a bit difficult. The most common combination for 331's and 337's was a 327 block (4.030" or 4.060" bore) and a 327 crankshaft with a longer 3.25" stroke.
          Old 283 blocks can usually be bored from their 3 7/8" size to the 4" of a 327 but going beyond that is a risk. Even 4.0" is pushing it a bit for long life and durability. Most old 283" were fine at .060" over though.
          If you add the 3.25" stroke crankshaft, you come up with a 327 at 4" bore and 331-337 with 4.03" and 4.06" stroke.
          A 283 block, bored .060" with a 3.25 stroke 327 crankshaft gives you 322.654 cubic inches.
          • Steven B.
            • June 30, 1982
            • 4011
            Thanks Michael! I have been trying to figure out how the Scarabs andother 50's sports racers got 331-339 out of the '58 283 blocks.
            Thanks!
            Steve
            • Michael H.
              • January 29, 2008
              • 7477
              Thanks!
              Steve
              In the 50's, it was more popular to use an aftermarket "stroker crank" that added a lot of cubic inches. (especially since there were no 327 crankshafts at that time)
              An old 283, bored to 4" with a custom 3 3/8" stroke crank comes out to 339 inches. That was a somewhat common engine in the late 50's.
              Betcha Clem built a few of those.
              • Steven B.
                • June 30, 1982
                • 4011
                THANKS!!!!!! Now I know. I guess they called Hank the Crank and others for the strokers.
                Steve
                • Mike M.
                  • May 31, 1974
                  • 8408
                  steve: call dean at cresap machine, 1 301 724 8794. he has the ability to make over 330 ci out of an old 548 casting and yet keeping the bore at 060 like mike hanson recommends(and i agree).he'll probably be a lot more reasonable than the california crankshaft manufactureres. mike
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Is he sneakin 350 cranks into those old blocks? It is possible.
                    Hey, by the way, I heard they're gunna be checkin cubic inches at the next event Mike.
                    • Steven B.
                      • June 30, 1982
                      • 4011
                      Thanks Mike! I have an extra seasoned block in the garage. Hummmm
                      Steve
                      • Henry F.
                        • April 1, 1979
                        • 68
                        I recall back in a 60's rod mag that a guy bored a small block into the water jackets and sleeved the block, don't remerber the bore/stroke, but it ended with 471 CI. and he installed it on motorcycle.
                        Hank
                        Hank Fredella
                        Vice Chairman Northeast Chapter
                        Charter Member (1982)
                        Webmaster www.necncrs.homestead.com
