Re: Original 1957-74 heat riser spacer for FI?
Ian,
The exhaust crossover that was mentioned before is not the exhaust pipe but the crossover in the intake manifold (or base plate). The carburated engines have an exhaust crossover that runs from cylinder head to cylinder head and is directly underneath the carburator. When the engine is cold (heat riser valve closed) exhaust gasses flow through this passage and heat the air/fuel charge coming from the carburator for better cold operation. Once the engine warms the heat riser valve opens and exhaust gasses can flow out the right hand manifold.
Fuel injected engines do not have this crossover in the manifold (or base plate) as it's not needed therefore the heat riser valve isn't needed so the fuel injected cars got the spacer instead. Rich
Ian,
