c-4 negative camber - NCRS Discussion Boards
c-4 negative camber
  • Mike M.
    • May 31, 1974
    • 8408
    c-4 negative camber
    anybody know of a source for offset a-arm shafts that would allow for more negative camber in a c-4. Old Farm Use needs more --cording front tires at a terrible rate. have gone as far as i can with standard suspention technique to achive camber that's currently not negative enough.mike
    • 43273
    Re: c-4 negative camber
    Mike-----
    I don't know of any source for such upper a-arm shafts. As a matter of fact, you could never even get the original shafts from GM as separate pieces. They were only available as part of the complete arm assemblies.
    While Federal-Mogul/Moog does offer off-set shafts for 63-82 Corvettes, they don't offer them, or even standard replacement shafts, for C4 Corvettes.
    If such parts are available, at all, I suspect a source like Doug Rippie Motorsports would have them or, at least, know where they are available. Unfortunately, I expect if they are available, they're going to be some high-dollar type, specialty racing parts which is probably not what you're looking for.
    • Bill M.
      • April 1, 1977
      • 1386
      Mike:
      Have you removed the "fat" washers in addition to the standard shims?
      How much negative camber do you have? I removed all my alignment shims and got to about -1.0 degrees. You'll get much more negative camber by removing the fat washers. (It was not an allowable modification in my class.)
      With BFG KD tires I got very even tire wear in many autocross events. Are you running a sticky (DOT or slick) tire?
      Bill
      • Joe C.
        • August 31, 1999
        • 4598
        Do you need this much:
        • Bill M.
          • April 1, 1977
          • 1386
          Using the same tires, he would even the tire wear out real quick!
          • David G.
            • May 31, 1980
            • 275
            Mike, I am going to change the upper control arm bushings on my race car this winter to add some negative camber.
            Dave
            • David G.
              • May 31, 1980
              • 275
              I guess that I should have added that these bushings will be offset bushings for this purpose.
              Dave
              • Bill M.
                • April 1, 1977
                • 1386
                Here's a link to offset lower control arm bushings:
