I'm getting ready to start assembling my L72 (427 / 425) engine. The short block is done, the heads are done (valve train installed). Does anyone have any advice for me? For example, I've heard that the heat tube through the intake manifold should be blocked off because the gas in the carb tends to boil on a long drive with hot weather. Also, it has a new cam. Comp Cams recommends degreeing the cam. The machinist that built the short block says that he didn't do it because it will not be raced. Should I degree the cam?
Joe
Joe
if you want heated intake in the winter just tap both sides of the intake thru the heat riser passage and run your heater hose in one side and out the other.
. You would never detect this slight power loss on a street engine. I just finished building a small block street stroker using a Comp Cam and the degree on #1 was right on.
