I'm getting ready to start assembling my L72 (427 / 425) engine. The short block is done, the heads are done (valve train installed). Does anyone have any advice for me? For example, I've heard that the heat tube through the intake manifold should be blocked off because the gas in the carb tends to boil on a long drive with hot weather. Also, it has a new cam. Comp Cams recommends degreeing the cam. The machinist that built the short block says that he didn't do it because it will not be raced. Should I degree the cam?
Joe
Joe
