68 Gas Tank Float Removal - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    Without have a special tool to take the lock ring off after the tank is emptied, can someone explain the best way to take the float out? Do you put pressure on the ring and then turn or just turn it by tapping the tongs on the ring?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Mike M.
    • May 31, 1974
    • 8408
    Re: 68 Gas Tank Float Removal
    there are three "teats" or tabs that you tap on , alternating between the three to keep the ring from going off center. don't ferget to drain the tank first.mike
    • Jack C.
      • 1090
      Thanks Mike.
      Jack Corso
      • Jack C.
        • 1090
        Mike, the stainer looks like it is fixed to the tube, is it removalable for replacement? I see Pargon does make a replacement.
        Jack Corso
          Just pull it off the pickup tube - it's a friction-fit; the new one just pushes on.
          • Clem Z.
            • January 1, 2006
            • 9427
            use a brass drift on the tabs not steel as you don't want and sparks with gasoline fumes.
            • Jack C.
              • 1090
              Thanks, all set to put the new tank in. I'll keep you posted in the next few days. Too bad my full time job interfers with the Vetteworks.
              Jack Corso
              • Jack C.
                • 1090
                Couldn't wait for the weekend. The Quanta tank arrived today and put in in tonight. buttoned everything up and filled her with gas. No leaks. Saved the original tank, cool to see the stenciled numbers on it.
                Jack Corso
