Water Leak Front Motor Mount 60 Vette - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Water Leak Front Motor Mount 60 Vette
    I put a thin coat of #2 on all surfaces or you can put just it on both sides of each gasket.
    One aid in assembling is to take some 3 or 4 inch long bolts (same thread as water pump bolts) or use threaded rod, and screw into the block in the top left and right WP bolt holes. Then assemble the gaskets, motor mount and water pump onto the bolts. Put in the bottom 2 bolts, snug but don't tighten, remove the top guide bolts and put in the proper ones. Then align as described by John Hinckley and tighten the WP bolts. Finish by lowering the engine and assembling the motor mounts.
    Take a nice ride and enjoy the fruits of your labor.
    • David A.
      • July 31, 1999
      • 147
      perfect!
      thanks to everyone on this site
      for helping me
      iowa
      • John M.
        • January 1, 2000
        • 175
        I had a 61 that every 150-200 miles would leak at the waterpump gaskets, the problem was a very worn clutch pilot bushing, it was causing a vibration you could not feel in the car, replaced the bushing and the problem was fixed.............Thanks JOHN
        • James S.
          • June 22, 2008
          • 226
          Yes, a very tricky set up, but so far no leaks!
          • Jim D.
            • 2884
            35 years and only had one leak about 25 years ago. Tightened the bolts and it's been fine ever since. Actually, the only time I've ever heard of this "common" problem is on the internet. None of my C-1 buddies have had this problem.
            • Mike E.
              • February 28, 1975
              • 5139
              Had the problem on a 62 fuelie in 1977--15 year old car that was born and raised in California. Never any coolant except from the factory. Rust did ithe bracket in. Have had 35+ C1's since, including the Gulf Racer which created plenty of torque--it never leaked. Only time I've ever had problems was when car had not been properly maintained, and then the fixes prescribed above always worked.
              • David A.
                • July 31, 1999
                • 147
                is this the correct permatex # 2 ??
                thanks
                iowa
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Yes, I use the one in the small tube.
                  • David A.
                    • July 31, 1999
                    • 147
                    #24
                    fine, thanks
                    i'll let this thread rest for awhile
                    and let you know how it all worked out
                    iowa
                    • Jerry B.
                      • August 31, 1994
                      • 416
                      #25
                      I had a similiar problem. My cure was to have the front motor brace machined flat on both sides and all is well.
                      • David A.
                        • July 31, 1999
                        • 147
                        #26
                        i have thot about the procedure above for installing the
                        gaskets, motor mount, and the water pump.
                        i plan to use the permatex # 2
                        and do the installation with these changes:
                        1st is to make sure all gasket surfaces are
                        spotlessly clean!!
                        then plan to use 4 sawed off bolts instead of two!
                        so the gasket bottoms will not drift off in any direction
                        will apply the permatex to both sides of the 1st gasket
                        and stick it on the engine front and then put in the 4 sawed off bolts
                        then the mount will go on
                        then the 2nd gasket w/permatex on both sides
                        then the water pump
                        while holding the pump in place
                        i'll put in the water pump bolts one by one
                        my new mount is on it's way from CS
                        so will let you know how it goes
                        iowa
