1970 LT1 Restoration - NCRS Discussion Boards
  • Hank S.
    • June 30, 2004
    • 2
    Hello all,
    I am new to the forum although I have been a NCRS member for a few years.
    I am doing a frame-off restoration of my1970 conv. LT1 that I have owned for 20 years; mostly stored. I request information regarding what tires I should put on it. I would like them to attempt to conform to the judging rules to not have point reductions, if possible, but still be good driving tires.
    Your suggestions would be well appreciated.
    Thank you,
    Hank Smith
    Culpeper, VA
  • Tony H.
    • May 31, 1993
    • 537
    Re: 1970 LT1 Restoration
    Hi Hank,
    The best thing I can offer is for you to get two sets of wheels. One set is the new bias ply repros mounted on your original rims with original weights on the insides of the rim so they do not interfere with the trim rings. The second set of tires would be mounted on another set of rims. This set gives you lots of choices. The bias ply and modern radials are night and day different. Use the bias ply tires for shows, radials for daily driving.
    Tony
    • Kenneth B.
      • August 31, 1984
      • 2091
      Originally posted by Hank Smith (42076)
      Hello all,
      Thank you,
      Hank Smith
      Culpeper, VA
      HANK
      Unless you have a set of NOS tires on the car you will lose some deduction. The repops will drive OK but we are all used to the radial tire. GOOD LUCK .
      KEN
      • Steven B.
        • June 30, 1982
        • 4000
        Hi Hank! I suggest you search the TDB posts as there are a number of suggestions on brands and sources in the past couple of months.
        Steve
        • Paul C.
          • November 12, 2007
          • 511
          The only original tire I have is my spare which is on an original rim. Only use it for judging. Take the point deduct and run modern tires---in my opinion the points are not worth the money--just like the battery --you will have to cosider $$$ versus points.
          Paul
