Starter clip - NCRS Discussion Boards
Starter clip
  • D S.
    • March 1, 2005
    • 1551
    Starter clip
    Did 1970 Corvette starters have those round clips that hold the wire harness? My assembly manual doesn't show it.
    Thank,
    Scott Sims
    Texas Chapter
    • 43271
    Re: Starter clip
    Thank,
    Scott Sims
    Texas Chapter
    Scott-----
    Are you talking about the spring clip on the solenoid with a clasp for the battery wire bundle? If so, yes, 1970 Corvettes were so-equipped.
      • 15630
      • Mike M.
        • May 31, 1974
        • 8405
        Re: Starter clip
        we had a 72 454 equipped chevy station wagon that had the harness retainer on its solenoid.mike
          • 15630
          Re: Starter clip
          With the solenoid heat shield on the BB starter seeing or feeling for that harness retainer is a lost cause.
          Hey Mike -- a BB station wagon sounds like a fun family truckster.
            Re: Starter clip
            Yes and no...illustration in the AIM...
            You'll find the clip called out in UPC 12 (electrical wiring) and not in UPC 6 (engine). The engine section simply shows the starter & solenoid being bolted into place on the engine without being electrically connected.
            In UPC 12, the engine harness gets hooked up and that's where the wire retaining clip is called out. When you flip to the back of the AIM where optional engines are called out, they only depict critical differences, so there's no mention of the wire retaining clip on the starter solenoid because it's already called out in the base car section of the AIM...
            • D S.
              • March 1, 2005
              • 1551
              Re: Starter clip
              Thanks all for the helpful replies. The next time I happen to be "casually fooling around under the car" I'll install one. The stuff around the starter and solenoid is so close to each other already!
              • D S.
                • March 1, 2005
                • 1551
                Re: Starter clip
                Jack, your reply reflects exactly what I was told over a year ago by the people that rebuild my alternators and starters. I forwarded your reply to them. That clears up some mysteries. Thanks to you and the others for your help and suggestions on the starter and clip.
                  • 43271
                  Re: Starter clip
                  Scott-----
                  You can't just "snap" the clip onto the solenoid. There are "loops" on either end of the clip and they will not fit through the space between the starter and the solenoid. So, at a minimum, you have to remove the starter brace to get the clip on.
                  • D S.
                    • March 1, 2005
                    • 1551
                    Re: Starter clip
                    Thanks, Joe. I read that part 'at a minimum' and figured "Oh, no. Nothing on that car has been at a minimum." Oh, well. I may have to remove the starter anyway this Texas Winter to get that shorter solenoid spring installed.
                    Our Winters here are usually about three months long and pretty much mild. I believe our average high temperature in the Winter is in the 50s. We often wear shorts and T-shirts at Christmas.
                      • 3418
                      Re: Starter clip
                      Hi Scott,
                      I think the clip actually addresses your point about things being 'close' down in that area. The clip 'neatens' things up a bit.
                      Having hands the size of a 3 year old helps too.
                      • D S.
                        • March 1, 2005
                        • 1551
                        Re: Starter clip
                        Thanks, Alan. You are right.....before I settled on my mechanic the one thing required on their "resumes" was the size of their hands. Those areas like behind the dash and in the engine compartment do require small hands.
                        My alternator repair people tell me to bring in the whole starter. If it's just the solenoid spring why not just bring in just the solenoid? I think they're into S&M.
