Carb gasket - NCRS Discussion Boards
Carb gasket
  • William M.
    • July 31, 1993
    • 390
    Carb gasket
    Is a 73 LS4 supposed to have a gasket between the carburetor and air cleaner assembly? If so what material and thickness is correct?
    It's the original Carter built Quadrajet 7043200 March 1973
    Bloomington Gold 2011
    Corvette Magazine 9/11
    Bloomington Gold 2013
    Corvette Magazine 3/13
    • 43279
    Re: Carb gasket
    William-----
    Yes, it is supposed to have a gasket. It was originally GM #3969843. It is a cellulosic fiber ("paper") gasket about 3/32" thick. I think that most were dark brown material but some may have been gray. I doubt that GM had a color spec on the material for a gasket like this.
    The 3969843 was discontinued more than 25 years ago and replaced by GM #25511809 which remains available as a functional replacement. Dr. Rebuild sells and excellent reproduction of the original gasket.
      • 15632
      Re: Carb gasket
      My observation of original cars leads me to believe the original carb to air cleaner gaskets for both Rochester and Holley equipped 1970-72 Corvettes were dark brown, however I have to offer the usual disclaimer -- that is I have not seen ALL Corvettes built for 1970-1972.
      And then there is the point that you asked about a 1973.
      • Kenneth T.
        • March 23, 2008
        • 631
        Re: Carb gasket
        Bill,
        My 71 LS5 quadrajet has a brown paper like gasket as Terry describes.
        How'd you get that Top Flight, the judges missed it?
        Ken
        • Todd L.
          • August 26, 2008
          • 298
          Re: Carb gasket
          Just wanted to say I'm jealous of the motor, my 74 LS4 looks nothing like that. Very nice!
          • Todd L.
            • August 26, 2008
            • 298
            Re: Carb gasket
            Would you be able to send me a picture of you air cleaner ring. I have not seen a proper LS4 ring.
            Todd
            • Harmon C.
              • August 31, 1994
              • 3228
              Re: Carb gasket
              Tod
              You can tell a LS4 air cleaner ring easy. A 350 ring is on center. The lip that holds the hood seal is the same size all the way around. That top lip on a 454 is offset and is about one inch off center so one side is lots smaller than the other.
              Lyle
              • William M.
                • July 31, 1993
                • 390
                Re: Carb gasket
                Originally posted by Kenneth Tozzi (48795)
                Bill,
                Ken
                No, I lost my 2 points, that's why I was asking
                • William M.
                  • July 31, 1993
                  • 390
                  Re: Carb gasket
                  Todd
                  Don't have any of the ring itself
                  • Harmon C.
                    • August 31, 1994
                    • 3228
                    Re: Carb gasket
                    That picture shows the ring in front on the top that has almost no ledge in front and an inch or more in the back the way a 454 ring should be. Did they have other items on the air cleaner listed for the two point deduction?
                    Lyle
                    • William M.
                      • July 31, 1993
                      • 390
                      Re: Carb gasket
                      No, carb and air cleaner were perfect except for missing gasket.
                        • 43279
                        Re: Carb gasket
                        William-----
                        Obtaining and installing the gasket is rather simple, so you should be able to correct this deficiency without problem. The next thing I'd do is obtain and install the AIR system. That had to be a much bigger loss of points. However, re-installing that will be a lot more difficult and expensive.
                        • Harmon C.
                          • August 31, 1994
                          • 3228
                          Re: Carb gasket
                          The white air filter on the hose from the valve cover looks like it may not be an original part. It is very white and may not have the logo A/C on the bottom or the staple but it's hard to tell in the picture.
                          Lyle
