57 trunk lock - NCRS Discussion Boards
57 trunk lock
  • Loren H.
    • August 31, 2002
    • 4
    57 trunk lock
    Is the lock escutcheon supposed to be flush against the lid surface? My lock hole has notches that fit the lock, escutcheon doesn't fit flat, it sticks out about 1/16".
  • Gary C.
    Administrator
    • October 1, 1982
    • 17942
    Re: 57 trunk lock
    Loren, should be flush with body. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Loren H.
      • August 31, 2002
      • 4
      Re: 57 trunk lock
      I have a problem then, the hole in the trunk isn't big enough for the escutcheon to fit in and be flush. The hole is notched the same way the cylinder lock is notched. Should I cut the hole bigger? The picture shows the notches & the hole being too small for the escutcheon to fit flush. What do you think I should do?
      • Gary C.
        Administrator
        • October 1, 1982
        • 17942
        Re: 57 trunk lock
        Loren, sorry if I mislead you. Meant to say flush with the lock and against the lip. Post your e-mail and will send you a photo. Unfortunately, I'm at max on photo attachments. Gary....
        NCRS Texas Chapter
        • Loren H.
          • August 31, 2002
          • 4
          Re: 57 trunk lock
          Gary, my email is alhelfenbein@comcast.net
