'61 Resistor Voltage - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    On a '61, 230 HP, what should the voltage be on each side of the ballast resistor? I assume it is 12v on the battery side, but what about the other side?
  • Jim L.
    • September 30, 1979
    • 1817
    Re: '61 Resistor Voltage
    With the engine off, you'll see slightly more than 12 Volts on the hot side of the ballast resistor.
    What you'll see on the coil side will depend on whether the distributor points are open or closed:
    Points open, you'll see slightly more than 12 Volts.
    Points closed, you'll something in the 6 Volt to maybe 8 Volt range.
    Jim
    • Roy B.
      • February 1, 1975
      • 7044
      That's why the wiper motor wire is on the 12V side , other 8 or 9 volt or the points burn
      • Richard P.
        • July 31, 2001
        • 173
        '61 Coil Voltage
        What should the voltage be on either side of the Coil with the engine off and switch on?
        • Roy B.
          • February 1, 1975
          • 7044
          Re: '61 Coil Voltage
          If you ever been at a drive in movie and it started to rain // that's why.
          • Richard P.
            • July 31, 2001
            • 173
            • Jim L.
              • 1817
              Assuming the coil is properly connected:
              The (+) terminal will measure the same as the "coil" end of the ballast resistor.
              The (-) terminal will be at + 12 Volts with the points open and 0 Volts with the points closed.
              Jim
