C2 gas filler neck sealant? - NCRS Discussion Boards
  • Dan H.
    • July 31, 1977
    • 1369
    Have had a 'dribble' from my 64 gas tank when filling to top of tank. Checked and sure enough it is leaking from the base of the filler neck. I ordered a new gasket but I'm wondering if there is a 'sealant' I should also use with the new gasket. Checked archives and couldn't find a reference to the sealant if used. Thanks in advance!
    Dan
    1964 Red FI Coupe, DUNTOV '09
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: C2 gas filler neck sealant?
    Originally posted by Dan Holstein (1440)
    Have had a 'dribble' from my 64 gas tank when filling to top of tank. I ordered a new gasket but I'm wondering if there is a 'sealant' I should also use with the new gasket. Dan
    Dan -- Also, the '65 AIM show no sealant; just the cork gasket. Mind you, the "screw assemblies" for the neck-to-tank connection have a plastic (?) gasket that will help.
    Installed a new gasket on my '65 convertible a few months ago, and I used a light coat of Permatex 'Ultra Black' gasket glue, only on the tank side of the gasket, more to hold it in place if I ever have to remove the tank again (as I don't think one can get it out with the neck still on).
    Haven't filled it up to check though.
      Wayne -
      You don't have to remove the filler neck to get a convertible tank out, but you do on a coupe.
        • 43246
        Dan
        Dan-----
        I love cork-----the feel of it, the look of it, the smell of it. I'd probably even like the taste of it if I were to eat any. However, I don't like it for the filler neck gasket. It tends to "dry out", displace, and leak over time. I used a sheet of buna-n gasket material about 3/32" thick to make my own gasket. "Bullet-proof".
        • Dan H.
          • July 31, 1977
          • 1369
          Thanks Joe, is the buna-n material available at Napa? Are there seals on the screws also? Been a long time since I had one apart! My old 63 started leaking but I just put another cork job on it! (in 1986)
          Dan
            • 43246
            Dan
            Dan-----
            It's been a long time since I did this. However, I think I had to go to an industrial supply vendor to get the buna-n material. I doubt that you'd find it in an auto parts store.
            There are integral seals on the screws and I suggest replacing these screws. They are GM #3767804 and remain available.
