67 Power Brake Booster Question - NCRS Discussion Boards
  • Lorne G.
    • June 30, 1988
    • 118
    My 67 big block has a 5867 number stamped on the left side tab and a 309 number on the back of the same tab.
    I was told the 309 number is the Julian date code of Nov. 11/66 which seems correct for my December 16th build. However I was told that the 67 booster should have a 7011 number instead of the 5867 number. I can not find anything in the Judging manual that gives the part number.
    Can anyone tell me which number is correct?
    Thank you in advance.
    Lorne
    • 43247
    Re: 67 Power Brake Booster Question
    Lorne
    Lorne-----
    I can tell you that the early 1967 power brake booster was GM #5455867 and has the derivative "5867" embossed on it. So, I would say that all is well for you. Later 1967 used booster GM #5458832. I THINK this one has "8832" embossed on it.
    I don't know what it says in the JG, but what I have said above is what I believe.
    • Michael H.
      • January 29, 2008
      • 7477
      Lorne
      Joe is correct. The 7011 was last used for the 65 and 66 model. There were some internal changes for the 67 booster which I think were a result of the new style master cyl used that year so I don't think GM would have used the 7011 even for early production 67's.
      • Lorne G.
        • June 30, 1988
        • 118
        Thanks for the information Joe and Michael. It sure pays to ask you guys the questions. I almost traded my original booster for a 7011.
        Lorne
