61 frame paint - NCRS Discussion Boards
61 frame paint
  • Richard P.
    • July 31, 2001
    • 173
    61 frame paint
    Is there a good over the counter spray paint for the frame of a 61 that works good and has the right color and shine?
  • Ray C.
    • June 30, 2001
    • 1132
    Re: 61 frame paint
    PPG has an OMNI line of paint (lower cost) that I used on my frame. You can purchase a flattening agent that will allow you to adjust the sheen from flat to full gloss. I purchased a gallon of catalyzed enamel and varied the sheen on all the chassis parts including the frame as per the 1961 JG.
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    • Jack A.
      • March 1, 2001
      • 129
      Re: 61 frame paint
      Hi Ray
      I saw you have a 61 315 H.P car. I also have one which I am currently just starting the restoration on. Any particular tips I need to know on restoring this one.
      Jack Alexander (35730)
      • Ray C.
        • June 30, 2001
        • 1132
        Re: 61 frame paint
        Jack,
        Restoration of your Fuel Injected 1961 should be the same as any other restoration project. You need to do your home work to insure you get the correct replacement parts, date codes and FI only parts. Research after-market parts, some are good and close to the original and others aren't even close. I have created a web page that provides some information that may help you. Many NCRS members have provided information and help with this web page. If you can provide pictures or information about your project I will include it on the web site to help others.
        If I can help in any way, just let me know!
        Ray
        Ray Carney
        • Christopher R.
          • March 31, 1975
          • 1599
          Re: 61 frame paint
          Do some research on this. I believe the frames were dip painted upside down. Therefore, if you want your paint job to look factory, you'll want runs in the paint, and you'll want them running up. Not sure, though. Get some more input, if you're having this judged.
            Re: 61 frame paint
            Chris -
            C1 frames were painted at A.O. Smith-Milwaukee hanging vertically, on hooks from an overhead monorail conveyor, rear crossmember down; they were dipped in a mild acid solution, then in a neutralizer, then in DuPont #475-763 self-etching black frame primer, then baked for 30 minutes at 325*F.
