Right behind the seats is an almost vertical cargo stop, which has carpet installed. On the other side of this piece, the carpet wraps around and then down to the cargo area.
There is the plastic parking brake handle cover which has two screws in the rear, holding it in place, which are located behind in the cargo hold.
My question is.... are these two screws just bolted in under the carpet or is there a cut flap in that area, like is done on the carpet for the seat support brackets? If there is supposed to be a flap, that would facilitate the removal of the parking brake cover. Thanks for any information.
PT
PT
