Re: 1971 LT-1 Valve settings?
Per the 2008 revision of the article referenced in a previous post I recommend .016/.023". That's it. Set them there and make a note to check them in 15K miles unless you have a nut that doesn't have much preload, in which case I would recommend replacing it.
At .034/.040" there must have been a hell of a lot of valve train clatter. At .016/.023" most guys would think it has hydraulic lifters, which is the way it should be. Properly set valve clearance on mechanical lifter cams should not be noisy.
