Sea Foam - NCRS Discussion Boards
Sea Foam
  • Wayne K.
    • December 1, 1999
    • 1030
    Sea Foam
    Anyone know what this stuff is made up of ?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Sea Foam
    http://www.seafoamsales.com/motorTuneUpTechGas.htm
    When Used Thru Injection or Carburetor
    • Cleans carbon build up
    • Cleans intake valves and pistons
    • Gives smoother idle
    • Cleans catalytic converter odors
    • Cures hesitations and pings
    • Restores power and pickup
    • With warm engine running, SLOWLY pour 1/2 pint through carburator, throttle body or direct manifold vacuum line that will feed ALL CYLINDERS. Possible sources are P.C.V. valve or brake booster line. Turn ignition off. Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short period of time.
    • Spraying water does the same thing down the Carb!
    • Joe C.
      • August 31, 1999
      • 4598
      Re: Sea Foam
      This product is 100 per cent natural and environmentally friendly*
      The Inconvenient Truth about its contents, or, its Guaranteed Analysis:
      30%---------decomposed human protoplasm (all natural-100% autolyzed and/or putrefied)
      30%---------decomposed marine fauna protoplasm
      20%---------SSSSSSSnake oyl
      10%---------chum residue
      5%----------methane (all natural-derived from post-mortem bloating)
      <5%---------flotsam and jetsam
      TRACE-------human ejaculate (may be higher if harvested from Caribbean beaches)
      * Al Gore approved
      Actually, most of these products contain a very high percentage of garden variety kerosene and/or #2 fuel oil, with some aromatics tossed in fer good measure.
      Iffen you wanna purge your engine of top cylinder deposits, a JUDICIOUS application of Roy's method works quite well!
      • Stuart F.
        • August 31, 1996
        • 4676
        Re: Sea Foam
        Sounds almost too good to pour down a carburetor. I think I'd go with the water as it is bound to be cheaper.
        Stu Fox
        • Dave F.
          • December 1, 2003
          • 508
          Re: Sea Foam
          The Land Rover owner's forum is moderated by a retired service manager and he swears by seafoam for the Rover V8 (an old Buick design from the early 60's with cyl. sleeves). I have yet to try it on my old LR but a lot of the members there have done it and all of them say the truck runs much better.
          • Jack C.
            • September 30, 1992
            • 1090
            Re: Sea Foam
            Bob Kunz recommended it for the tank after I had him do my carbs. I tried it and did it really make a difference.....................I really don't know but his rebuilds were great.
            Jack Corso
            1972 Elkhart Green LT-1 Coupe 43,200 miles
            Top Flight 1994, 2018 & 2021
            • Stephen B.
              • April 1, 1988
              • 876
              Re: Sea Foam
              I pour transmission fluid down the carb while keeping the engine running. It makes a lot of smoke but seems to clean the inside of the engine well. You can tell by the better idle. Typically, I pour a quart through the engine before I drive it on the interstate for a few miles.
              • Stuart F.
                • August 31, 1996
                • 4676
                Re: Sea Foam
                Trans fluid added to the gas tank is said to clean the injectors on newer cars. I've done it, but can't say it did much.
                Stu Fox
                • Tom K.
                  • February 26, 2008
                  • 167
                  Re: Sea Foam
                  I don't know what it is made of, but I use it as a winter fuel stabilizer in my caes and in my boats instead of Stabil. It has been recomended by several marine dealers as beter than Stabil. I bought a boat with a 150 hp motor that had been sitting for a couple of years. It ran OK at first but after a few hours of use it wouldn't idle. After a couple of cans of Sea Foam it started running better and has been for last 3 years. Iuse it every fall as a fuel stabilizer.
