Well I decided to go with the rear flaps. Here is the ultimate template for the carpet cuts:
Yep, used the tracks themselves as the template for the carpet cuts. You have to take the seats out anyway, why not take the tracks off and use them positioned to the bolt holes.
Bolted down and with the cuts made, things look nice and clean:
Here's a closeup of the rear flaps bolted down:
Bet you can't even tell the flaps are there.
However, I can see why they may have done a full cut on the rear pads on the assembly line.
Try setting the seat with the tracks attached and with only two hands. You need at least three hands to set the seat and lift the flaps over the pads, then set the bolts. What a PITA, took me about 20 minutes per seat with lots of expletives.
For you bolt guys, here's and original seat bolt (which I black phosphated when I did the seats a few years ago):
It's a recessed head hex with captive washer, and a head marking of L surrounded by a G.
The little strip of carpet in the background (approx 1" X 2") is the only thing I cut out for the rear seat pads. It fits nicely into the back of the track, so I'm going to leave it there per Mike Murray's advice.
Having fun,
Having fun,
