1965 396/Air Battery Box Bolts & Washers - NCRS Discussion Boards
  • John O.
    • June 30, 2000
    • 88
    During the installation of the battery box on a 65 396 we noticed that the kit contains bolts with captured washers and also larger washers. We are debating whether the larger washers are correct. There are some shown in the AIM, but we've seen a low mile Duntov car with only the captured washers...no larger washers. If you have any information about what is the correct installation it would be greatly appreciated!
    Thank you,
    John
  • Jim L.
    • 79
    Re: 1965 396/Air Battery Box Bolts & Washers
    Thank you,
    John
    John, i viewed my 65/396 and those thick washers are in place and have the same part number for those used in 63 as well. I measured one, od dia is 1" and the thickness measures .0125. My 63 measures the same as well.
    I talked to you at the National Convention John about a starter assembly fo this Corvette and failed to get back with you on a time frame of completing of. We talked about the need of a solenoid as well. Please let me know your intentions.
    FWIW-Jim
    Jim Lennartz - FWIW
    1963 SWC
    Duntov Award
    Bloomington Gold
    Gold Spinner Award
    Triple Crown Award
    Platinum Award in Class
    Best Restoration in Show
    • Rob M.
      • June 30, 1999
      • 171
      Bolt and washer configuration should be the same as an AC car as a reference. I ended up putting the large washers on my 396.
      Rob
      My Project Pictures
      http://temp.corvetteforum.net/classics/l78vetteman/
      • Donald S.
        • January 23, 2008
        • 183
        hi on my 396 car the battery tray bolts have no captured washer and use a large washer 1/8 thick 15/16" in diamiter bolts are 5/16" NF 3/4 long and self threading ,the bolts have a recessed head with a D in the middle I could post a pic later if required . Don
        • John O.
          • June 30, 2000
          • 88
          Thank you for the advice everyone. Jim, I sent you a PM regarding my starter. Don, if you have the time, I'd like to see the photo of your configuration.
          -John
          • Donald S.
            • January 23, 2008
            • 183
            hi john sorry to be so late with the pic's but this is my origional battery tray outer bracket welded to a new tray , hopfully you can clearly see the outline of the large washer on the bracket .. when i removed the bracket from the frame there were 5 of the 6 bolts still there and i beleive them to be origional .. i did not mention before that also on the head marking there are three circuler rings arround the D on the head ,good luck Don ..
            • Donald S.
              • January 23, 2008
              • 183
              i forgot a pic of the washer sorry ...,also the head markings dont show up well i will try and take a better pic tomorow ..Don
                "the head markings dont show up well"
                Check out your digital camera's owners manual. Somewhere, I'm pretty sure, you'll find there's either a button to press or a configuration menu entry to invoke to put the camera into 'macro' mode. Once you do that, your closeups will be crisp/clear at the expense of shooting pix with normal distances to the subject...
                • Donald S.
                  • January 23, 2008
                  • 183
                  camera all figured out ......
                  heres a pic of the bolt head up close and personal... lol .Don.
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    Re: camera all figured out ......
                    Don -- here's one of the bolts on my early '65 air car; those on my late 396 look the same (without removing to check; the inboard two are easy to see). Same D headmark in circles; indented hex 1/2" head on a 5/16" - 24 bolt (fine thread). Thick washer is 1.0" dia. by 1/8" thk.
                    • John O.
                      • June 30, 2000
                      • 88
                      Don & Wayne,
                      Thank you for the photos. We were leaning towards not using the bolts with the captured washers.....unfortunately I don't have any with the D headmark
                      John
                      • F S.
                        Infrequent User
                        • January 1, 1981
                        • 28
                        Would you happen to have any pictures of the battery tray? I understand that the battery trays have some type of triangular cut out in the corners.
                        • Harry S.
                          • July 31, 2002
                          • 5296
                          Look at LIC part 26-06C
                          • F S.
                            Infrequent User
                            • January 1, 1981
                            • 28
                            Will do, thank you.
                            • F S.
                              Infrequent User
                              • January 1, 1981
                              • 28
                              I did, but that was a wrong number. It was 27-20 in Long Islands catalog. Thats the one I have, and I was knocked for it being wrong . Supposed to have some "triangular " cut outs, I was told. Thanks for the trouble. FRED
